Flash Blend
Doc Crappie
Banned
Folsom, Pa
Fatman said:
Sorry I don't eat at McD's or Burger King - they charge too much and I can make better tasting food at home
Then that means you have lots of extra pocket cash so why you always complaining about the price of things. Get over it nothing is getting cheaper these days and I don't think that is going to change anytime in the near future. Sometimes you just have to say hell with it all and just do something that you wanna do and do it. Do something that makes you happy and feel good, life is just to short to always wish you had or wish you did. Nothing personal here FM but we are not getting any younger here or at least I know I'm not so I plan on doing things I like and enjoy while I still can, so price is not issue within reason.
Sent from my PC36100 using Tapatalk 2
jiggerjohn
JJ1, If ya have that spinner moving good in water,then you're all set! I give mine the "blow test" after I install the propeller& cone & later after I tie material on ; if it twirls quickly & easily at a slight breath, it's a winner!When fishing,I check every cast that the blade is spinning vigorously at the end of the cast -if not,I instantly go over the 1/4" gap from the jighead with a (purposely) long thumb nail or thin knife blade to remove the trace of weed that is sure to be there! I've found that if that propeller isn't spinning,the Boolie is 75% less effective!!
As to the tie-always tie thin! I found on my regular Boolie version that I had better results with about 3/4" of mink zonker,because it was thinner & less height of hair than rabbit, and long ago discovered more than 4 strands of flashabou as a tail got in the way! Heck, these days, I even shave my rabbit fur mostly off, in a leech variation, and just use the fuzzy hide when I do go with bunny strips! But the SJ blend ,I'm finding, is best in a really narrow pinch; this stuff throws off so much light from its translucents that I think the "holes" among the ultra thin fibers is the biggest aid! Tie yourself one so thin that you can barely see a tail,then watch it in semi clear water-quite visible & superior action (stimulated by the propeller) to any thicker tie.What I'm enjoying is watching even smaller panfish with the SJ Blend tails sucked all the way down to their throats(easily hooked in their front upper lip) -of course bigger mouthed crappie &bass just annihalate this "ghost minnow"!
It definitely worked for me this morning although I'm probably using to much.The dart head worked really well and with a little fine tuning on my part this will be killer. I'm really impressed with the results from day 1. I'll tie some thinner one's and try them out sometime this week. I need to throw some in the rivers I fish.
Well that extra cash goes to pay bills!!! And $5 bucks when I have something just as good I can put the $5 bucks in the gas tank!!!!!
I tried the blow test on the prop after I finished one tonight and had duck feathers everywhere. Not one of my finer moments.
I bought some of this sf flash blend a couple years ago, and tied some jigs with it but never fished them. I was put off by the fibers being a little stiff. however I never tried tying the jigs very sparsely like ya'll say works best. gonna have to dig this stuff back out. It does have a very flashy transluscent look to it. I don't know about the prop thing, Iv'e tried that before and any little thing in the water hangs up on it, maybe for open water fishing.
Duplicate post from similar topic:
To clarify, the smallest props are the small size fly props distributed by Wapsi, usually in packs of 24. The so called other "small" #1 lure props from other mfgs are larger and I believe equivelant to the Wapsi fly mediums.
It is essential that the props and bead or cone stopper bearings fit over the hook barbs. Barb sizes vary with hook brands and even batches within brands but generally the small Wapsi fly prop hook fit is #8 and smaller. The next bigger #1 lure props fit #6, #4, & #2 hooks with the larger #2 and #3 lure props for bigger hook fits. Its possible to force a slightly too small prop past a barb but at some point the barb may flatten.
For best prop function the hook shank spin area should be smooth & paint or lead flash free - a razor blade works. It takes some practice to adjust the shank spin gap between head and bearing stopper to ones preference. JiggerJohn likes a large gap because it is easier to clean out trapped weeds and debris. As "Redear" suggests the Boolie jig works best in clean open water.
I bought this flash blend at bass pro and got a gray color as well as one called shrimp I believe, it looks like a natural polar bear color, have to get it back out and look at it. Am glad ya'll found a use for this stuff as I just figured that I wasted my money and stashed this stuff away. just goes to show you never know. I was tying it full bodied on my threadnecks and in the pool it had no action at all, so with the sparse tying maybe it moves a little.
also read one time that this steve farrar flash blend comes from south africa, may account for the cost of this stuff.
alright jiggerjohn, since it looks like were all gonna jump on the boolie jig bandwagon, I gotta ask, where did the name " BOOLIE" come from?
jiggerjohn
Redear, Actually Hawnjigs came up with the name from our correspondense and his initial sucess. He named my original small jig ,tied on his alloy heads, a "Basher" for the bunny&flashabou (plus calf tail) that I tied. Then when I began installing the props & cones, since they pushed back &cramped the thread a bit and it had a "woolie bug" appearance, it was a combo of bunny &woolie,he figured, so it became a "Boolie". And with the SJ Blend they become "Ghost Boolies" or just GhostBoos!Below is a list of notes on this pattern, as obsrved on the recent weekend trip that you may enjoy ;
Thought I'd list ,in no logical order, some of the things I saw at Vermilion(ohio) while testing the SF Blend "Ghost Boos", which I used exclusively. Now, the water color was dingy from the past week's waves,but not too bad-you could see the lure a few feet down,and make out SOME rock ledges & boulders. Some chop -especially yesterday early morning. But a few items here that can help both of us in shoreline jigging other freshwater spots! Here they are :
1) Redfish SF blend is HOT! Kind of a transparent orange that appears from above to be quite visible.Really good around rocks- a crayfish look? I'm gonna make a bunch of two tones with this orange tied as the belly.
2)Best retreive was 2 or 3 slow cranks, then let sink toward bottom. They took mostly on the drop.
3)Fish actually hold on to this crunchy material. Hooked some after the jig had bottomed, then noticed a swim -off ! Lost what may have been a nice carp or cat(woulda taken my species total to 14 !) as I stood their in a stupor as I wondered why the jig was moving slowly sideways after it touched down in 15' ! Got some nice crappies that held on after sinking deep.
4)5# Tectan mono is way superior to 5# Power Pro for dropping & sinking a 1/24 oz Boolie
5) My longer 6'3" old Skyline light action graphite rod allowed better working and control off the pier than did my 4'6" rod-superior distance & hook setting
6)In current, work the sideways drift as well as the drop -both are superior to a steady, straight retreive
7)Little hand scissors are easily accessable in your side pocket and prove to be the best to quickly remove moss & weed from around the propeller-just some quick scraping with both scissor blades at once
8)!/24 oz LEAD jigs are way heavier than your 1/24 oz alloy roundheads, and the leadhead doesn't give the nice glide and swim that yours do!
9)On the glide & swim in streams the 1/75 oz Boolie stays mostly horizontal, even when dropping free
10) The 1/75 (1/64?) Boolie spins constantly in stream current -even while drifting sideways
11)Retie GhostBoos OFTEN -rock & fish abuse +zebra mussels wears 4&5 lb test. I didn't have any fish break me off, but lifting a meaty sheepshead up the 3-5' distance to the pier almost always saw the line snap & a Boolie lost!(hey, like potato chips, I can always make more!)
12)Set with just increased rod PRESSURE(mostly from the REEL!), not a jerk or rip. Lots of strikes can ONLY be detected by an increased bend in the rod tip!
13) Don't plan on feeling many strikes, and in slight stream current even LESS(we're down to about zero actual feel!!) -just be aware of tiny increased line tension when starting a retreive
14)In Stream fishing, TENKARA rods No reel, a form of ultra-finesse Japanese fly fishing) with tiny ghostboos are really fun & effective! But light spinning rods & thin line is almost as good -even 1/64 can be cast 15-20' or more with light line
15) In streams, look for big rocks, even in relatively shallow water, and let an orange Ghost Boo drop right down beside it -unseen are crevasses where smallies & rock bass hide & they dart out to grab when something crab like and noisy plunks down beside their lair
16)Quesstimate when shallow bottom is reached in streams following a drop of the bool, then tighten a Tenkara rod (there is no "setting" or lifting with these wimpy sticks!)-more often than you'd expect, there's a nice fish holding on
wow, thanks for the info and history on these jigs! I'm going to bass pro friday after work and see what they have.
jiggerjohn
Quiv Kid, When famed fly guy Bob Clouser put me on this SF Blend and I asked him point-blank about HIS top colors, he preferred the "simple" gray & white versions!! Altho he has a soft spot for chartreuse & mentioned many pike & muskies this Spring which fell to his bigger "Wild Hybrid" streamer flies in mostly bright chartreuse patterns. Bob also turned me on to the dull orange shade, known as "redfish" - I was just looking at some Boolies I tied last night and realized it's a very good replica of the Erie MAYFLY that all fish in the big lake eat to the exclusion of everything else when they emerge!(no wonder I did so well up there last weekend!).
found some medium wapsi props and beads this morning, plus some orange, and also camo sf blend, so will have to order the small props and the redfish blend, the medium props are still pretty small, they should work on a 1/16 anyway.
oh, the camo sf blend reminds me of baby bass color, and Iv'e always had luck with that color in ponds and lakes around here.
