pics 7 and 8 are of my press frame, showing the bottle jack positioned for pressing a mold. I like to lay the mold on the bottom cross member with the blank head sandwiched between the mold halves, and then sit the jack on top of the mold, sometimes I sit a steel plate on top of the mold first to protect the cast iron base of the jack since the mold is smaller than the jacks base. when pressing a mold the brass alignment pins are extra long allowing the mold to be opened up far enough to get the blank head in there. you need a copy of the head you want to replicate, we call it a blank, and it is best made from steel, a lot of mine have been made from the butt end of a drill bit and I make the blank by chucking the bit in my lathe with the butt end sticking out and as it turns I hold a cutting wheel 1 inch in diam. mounted to a dremel tool against the drill bit and cut it down to the shape I want, after that I use varying grits of emery cloth to polish it,
