scott, I use my do it molds all the time and think they are great, but they don't offer just what we want sometimes. have been wanting to get a custom mold cut for several different ideas I had, and have been putting it off for so long because of the cost and you don't know if it's gonna turn out just like you had in mind. so this is just a way of having total control over the shape and balance of the head, and if you get it wrong the first try you haven't lost but a couple little chunks of aluminum. I believe a person could get away with alot less equipment than what I have to do this. If you had a welding shop weld you up a basic iron frame, then you could probably get away with just having a drill or drill press, even a little bench top model, to spin your blank while you shape it. bottle jacks are cheap too. redman even said he just used a couple peices of channel iron with 3/8" threaded rod and nuts and lock washers to make his frame. I just went overboard with the 3" square tubing 3/8" wall thickness and welded upright supports, because it's just my nature to go overboard. lol the iron and aluminum will cost you some. I have 38 bucks in the iron with some left over and 40 some bucks in the aluminum which is 48" worth. 4 inches per mold and I have at least eleven molds out of the 48".
