Finished rods ...
Couple months ago, posted a few rods that I was building
Here are the finished rods:
The butt section of the rod on the left has a holo-wrap. Basically, it's a white black base, with four coats of epoxy, then a reverse wrapped double thread of metallic green & white. The white is called a 'slave' that after the wrap gets removed causing a holographic effect.
Lotsa work but very cool if you're trying to add a little weight to the butt for balance
If you look at the guides closely, you'll see that an imaginary line from the shaft for the spool of the reel goes right through the guides until it intersects the blank. Then after that are small micro guides that shoot the line off the blank. This is called a concept spinning set of guides.
Theory is longer casts. The topic's debated heavily among those in the know. I think it does add distance to the cast, but what do I know. lol
Thx everyone.
Been building now for almost 10 years as a hobby. Makes great gifts to friends & family.
Nothing like catching a fish on a rod & bait I built.
Concept spinning from Fuji - in Alconites and Silicon Carbonite guides
Theory is two cone's of flight. First cone is an imaginary line from the shaft of the spinning reel to where the line intersects the blank. From the intersection of the blank to the tip the line shoots off with fly guides. I modified the theory slightly by going from a 7 to a 6 size fly guide and then found out St Croix did too. Guessed right on that one ... if guides are placed right, you can see the theory in motion with each cast. Rumor hazit that you get about 20% greater casting distance ... this rumor's heavily debated on the forums, but I like it.
Here's a good article
http://www.rodbuilding.org/library/spinningNGC.pdf
NorCoMike
Northern Colorado
Nice looking rods! I'm a big fan of the concept guide placement. I don't think I could go back to a conventional guide train.
Sent from my SAMSUNG-SM-N910A using Tapatalk
Collecting the parts for another rod. I've had a 5S70MF waiting to get built for a couple years. Got a killah deal on the blank.
Saw these in the recent Mudhole catalog & bought a skeletal pair of composite fiber grips
Still filling the penny jar for a set of Ti SIC guides
Haven't decided any other color patterns to the wrap but since the blank's green, I'm sure I'll have some green in there some wheres.
z520tom
Kentucky
The micro guides on the tip section of the rod will greatly enhance the sensitivity also. They take all the weight from the larger running guides off the tip section. I have used the micro's on all the rods I have built for the last six years. They are the way to go.
