Thanks for the post, always hard to keep them shape.
Another tip: between sharpening you can use a piece of ten foil to keep a good edge. I fold a piece around 4 times and make it as wide as my blade. Cut the tin foil 10 times and it takes the edge off the blades and you are good to go.
Can't remember when or where I read this but it works.
