This pattern has been very successful for me on smallmouth and crappie in murky water and on moonless nights. The body is Estaz Metallique and the tail is black Arctic fox. Marabou and rabbit have also worked well for me. The black color and longer fibers give the jig a chunky profile and silhouette that's easy for the fish to see, and the metallic fibers reflect any available light. Probably a bit too flashy for clearer water, but it really does the trick under reduced visibility conditions. With the wedge-shaped walleye head, fat body and tapered tail I'm sure the fish think it's an unwary minnow or baby perch.
I've had the best luck with casting it out under a bobber and letting the jig sit for a few seconds and twitching it gently. If that doesn't get a response, I start reeling slowly but steadily. When I get back to the shore, I stop reeling and twitch it again like a minnow that has just realized it's in trouble in case a fish has been following. You wouldn't believe how many times the smallies hammer it almost at the tip of the rod.
