hot pot II
stanger1944
LA Lower Arkansas
So what do you think of the hot pot II for lead pouring on a fairly small scale? Has anyone used one and know how well they hold up, and how well that it melts the lead?
They hold up for years . Just don't set them on metal surfaces that retain heat . It sucks it out of the pot and it will keep trying to heat until the element burns out . I killed mine by setting it on a cold cast iron stove in the winter .
Ron Don
West Monroe, LA
I personally would save up a lil more and go with the bottom pour! I think you would be glad u did in the long run.
Certain Do-it small jig head molds won't pour with tilt ladles. For those you need the melt drop pressure of a bottom pour.
jig-guy
Hesperia CA
Lee bottom pour hot pot. It will be worth the money and you can put the lead where you want it to go. I make large jigs most of the time and use a ladle and use a Lee magnum melter with a 3" large ladle. The smaller stuff I still use my bottom pur hot pot.
I hope this helps.
jig-guy
Hesperia CA
Hay stanger1944, good for you. You will be happy using that pot. Be sure to follow safety 101 and enjoy making your jigs.
